List connections
Retrieves all connections and associated data for the Embedded customer account. Requires oem_vendor
privilege.
Path parameters
managed_user_id
Embedded customer ID (external ID). The External ID must be URL encoded and prefixed with an E
. For example, EA2300
Headers
Authorization
Bearer authentication of the form Bearer <token>
, where token is your auth token.
Query parameters
provider
The application type of the connection, for example, salesforce
folder_id
The ID of the project or folder containing the connection.
parent_id
The ID of the parent connection, which must be of the same provider type.
external_id
The external ID assigned to the connection, typically given to the user who owns the connection.
include_runtime_connections
Includes all runtime user connections when set to true
includes
Specifies additional fields to include in the response. Accepts tags as a value. If tags is supplied in the request, the response includes a tags field for each connection. This field contains an array of zero or more tag handles (strings).
Response
Success reply
result
