Developer API
The Workato Developer API offers access to a wide range of Workato resources that enable you to manage recipes, connections, jobs, and more. You can use this API to automate every aspect of your Workato workspace, from deploying recipe manifests between development and production environments to rolling out new on-premises agents within your network landscape.
Base URL
The Workato API is a collection of API endpoints for interacting with Workato users, recipes, and more. Each endpoint contains the base URL and the resource path to the object.
The base URL of the API endpoint depends on the data center that you use:
- United States (US) data center:
https://www.workato.com/api/
- Europe (EU) data center:
https://app.eu.workato.com/api/
- Japan (JP) data center:
https://app.jp.workato.com/api/
- Singapore (SG) data center:
https://app.sg.workato.com/api/
- Australia (AU) data center:
https://app.au.workato.com/api/
Authentication
Workato API uses API tokens to authenticate requests. You may generate an API token by creating an API client under Workspace admin and assigning it both a client role and project scopes.
LEGACY API KEY DEPRECATION
Prior to API clients, Workato’s API used a legacy full access API key and email in request headers or the query parameters to authenticate requests. This will continue to be supported with your legacy migrated API client that represents your API key and email. We strongly recommend migrating over to API Clients for authentication to Workato APIs. Learn more
Legacy API keys will be supported until 1/1/2024 and will be deprecated thereafter. All API requests authenticated via legacy API keys will start to be rejected after this point in time.
Provide API tokens as a bearer token
Provide your API client’s API token in the request headers as a bearer
token.
Supported Formats
Workato API supports sending request body with the application/json
content-type. All replies are also encoded in application/json; charset=utf-8
How to generate an API token
You can generate an API token by creating an API Client under Workspace admin and under the API Clients tab. Find out more about configuring API clients and roles.
PERMISSION REQUIREMENTS
You must have the following permissions to create or edit API clients:
HTTP response codes
200 Success
The 200 Success
response indicates that the request was processed successfully by the server. The response body varies depending on the endpoint and operation performed, but it typically contains the requested data or a confirmation of the action performed.
Sample reply
400 Bad Request
The 400 Bad Request
error indicates that the server couldn’t process the request due to client-side issues. Common causes include malformed requests, invalid fields, or violations of field constraints, such as unsupported data types.
Sample 400 reply
401 Unauthorized
The 401 Unauthorized
error is returned when the request lacks valid authentication credentials. Common causes include missing tokens, invalid tokens, or incorrect credentials.
Sample 401 reply
403 Forbidden
The 403 Forbidden
error indicates that the client is authenticated but doesn’t have the necessary permissions to access the requested resource.
Sample 403 reply
404 Not Found
The 404 Not Found
error is returned when the requested resource doesn’t exist or can’t be found. This can occur if the URL is incorrect or the resource has been deleted.
Sample 400 reply
500 Server Error
The 500 Server Error
code indicates that the server encountered an unexpected condition that prevented it from fulfilling the request. This error is usually caused by server-side issues.
